Blue smoke coming from exhaust when car is turned on when cold
92,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
OSCAR QUINONES
I have a question hopefully someone can can answer. I am a college student and recently got this car for school. Car runs fine and everything is good but when I turn my car on in the morning when it is cold or when it has been sitting four or more hours a big cloud of bluish smoke comes out of the exhaust. I have been told it can be the piston rings, valve cover gasket, or the valve stem seal and I know the piston rings are expensive to have a mechanic fix it. Would you possibly know what it is? I do not want to fix all three and have a $1,000.00 plus bill to fix it. Thanks in advance! :)
Apr 12, 2017 at 2:25 PM
STEVE W.
  • 15,387 POSTS
Blue smoke after setting and on initial cold start is 99% of the time, bad valve stem seals. The other 1% it is a plugged up return passages in the head not allowing the oil to drain back into the pan. Toyota had a problem with some engines forming oil sludge in them which caused oil flow problems. In your case I would suspect it is a combination of both.
As for your list of suspects.
Stem seals would cause blue smoke at initial start because the oil can leak past the valve stem seal, run down the stem and pools on the valve or piston. When it burns off you get blue smoke. But normally only on initial start because they are not leaking real bad.
Valve cover gaskets - normally this will lead to oil leaking outside the engine and or into the spark plug wells. No blue smoke because the oil does not burn, although it can stink like crazy as the engine gets hot and it could drip on the hot exhaust and cause smoke from under the hood, but not out the exhaust.
Piston rings - These being stuck, carbon blocked, or broken will show up as lost power and almost constant blue smoke that gets worse as the engine heats up.
My suggestion is to have the valve stem seals done, have the timing components changed as well as pulling the oil pan off and cleaning the lower end of any sludge build up. Not going to be real cheap, but it gives you a better starting point. Then use a synthetic oil for your changes.
Apr 12, 2017 at 11:12 PM
OSCAR QUINONES
Thanks for your reply. I will get the Valve Stem Seals done and also clean the oil pan. As for the timing components is this what you are talking about? Thanks again this really gives me some reassurance! http://www.carparts.com/details/Toyota/Camry/Replacement/Timing_Chain_Kit/2004/REPT300101.html?TID=gglpla&origin=pla&gclid=Cj0KEQjww7zHBRCToPSj_c_WjZIBEiQAj8il5JG4s_pobbstmHdtLNLPdSX8uIQxwcdvjwicJldJTKEaAhxR8P8HAQ&gclsrc=aw.ds
Apr 13, 2017 at 12:43 PM
STEVE W.
  • 15,387 POSTS
Those would be the ones. I would inspect the ones you have but what happens a lot is those long guides get worn then bad things happen. With the fact that the cams have to come out to do the stem seals anyway, it's a good way to be sure they don't cause an issue. Plus it allows more cleaning.
One item to check close will be the valve guides. With the stem seals leaking you will want to determine if that was caused by guide or stem wear. It might be cheaper in the long run to have the head rebuilt with new guides and valves than just doing the seals. But you can't find out if they are a problem until the engine is open. Sort of a catch 22.
Apr 13, 2017 at 11:53 PM
