blue smoke
2008 TOYOTA
56,473 MILES • 1.5L • V12 • RWD • MANUAL
TSEPO
what makes a Avanza to have a smoke on a exhaust pipe?
Jan 19, 2017 at 4:16 PM
TSEPO
i think it is a seal, but i am not sure.
Jan 19, 2017 at 4:18 PM
CARADIODOC
  • 34,413 POSTS
Did you really mean to say, "on the exhaust pipe"? That would imply oil is dripping onto it from the engine, and that would indeed be caused by a leaking seal, most commonly a valve cover gasket. You'll see and smell the smoke, but it won't be blue.
If you're seeing blue smoke from the tail pipe, that is a sign of burning oil in the engine. Typical causes are worn valve guide seals, worn piston rings, an inoperative PCV system, and oil that has been diluted with gas.
Jan 21, 2017 at 6:29 AM
TSEPO
the is no oil on the pipe the pipe is dry its smoke if i worm up the engine after is stop wen the engine hot but no oil leak on the pipe and smoke is blue.
Jan 22, 2017 at 12:34 PM
  • 55,676 POSTS
Hey TSEPO
We have a great guide on hwy the engine will make blue smoke.
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
Please let us know what you find.
Best, Ken
Jan 25, 2017 at 1:19 AM
