Pep boys did a test and seen there was oil and coolant mixing somewhere in the engine but they couldn’t figure out where, so they’re saying I have a blown head gasket, may that be the case is it worth fixing? Or should I just replace the engine? People say if you just fix the gasket, it will happen again shortly after it’s fixed. Is that true?
Sep 16, 2019 at 8:39 AM
