Blower only works on highest setting
133,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
BKRGUY
Only works on highest setting I replaced resistor and it soved problem worked on settings 1-4 week later same problem only works on 5 nothing on speeds 1-4 flaps what next? replace blower motor?
Dec 3, 2015 at 10:11 AM
  • 110,248 POSTS
Most likely, the motor is drawing too many amps and burning up the resistor. So I would say you are correct.
Dec 3, 2015 at 10:19 AM
BKRGUY
Ok thanks. Last question. Do engine cleaners work ? If so what brand? Fuel system cleaners? Best front brake pads ?
Dec 3, 2015 at 10:44 AM
  • 110,248 POSTS
Yes, engine cleaners work to some degree, but won't work well unless you have a high pressure washer. PLEASE, make sure not to hit electrical components too hard as well as injectors. Too many times I have seen people ruin parts that way. They clean the engine and then it develops a misfire. Ugh...
As far as the injectors, I'm not to talk about products by name because people may think we are getting paid to endorse them. That couldn't be farther from the truth. We are not. I can tell you this, I have had injector issues in the past. A can of seafoam injector cleaner usually works for me.
As far as brakes, I always use Raybestos. Years and years ago, when I was learning to work on cars, my shop teacher always said use a good brand. He mentioned that name, and I have always used them. Never a problem. I assure you there are other brands which are good: Bendix, Wagner...
Take care and let me know if you have other questions. If I don't hear from you, have a great Christmas and New Years!!!
Dec 7, 2015 at 10:32 AM
