Turn signal click sound is not working?
180,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
GEORGEMERHY
Hello, my blinker or turning indicator sound is not working. Is there a way to fix it? Is it a fuse problem or speaker problem? Thank you
Dec 1, 2024 at 10:13 AM
  • 55,808 POSTS
The turn signal sound is generated by a speaker or piezo buzzer in the instrument cluster. But it could be a BCM issue, or the system needs to be updated. I would try a hard system reboot to see if that helps, this guide can show you how:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
If this does not help, I would do a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Please go over these guides and get back to us.
Dec 2, 2024 at 2:30 AM
