2015 Chevrolet Malibu No Defrost Heat
I attached a YouTube video for you to view.
https://www.youtube.com/watch?v=pjPcHzMhPGU
Sorry, the video is for the blend door which is on the passenger side.
Suggested Repair
Treat this as a mode door actuator issue, not a blend door. It is on the driver's side of the dash and can be reached from under the left side without removing the dashboard. Remove the left floor air outlet duct, which is held by a clip or small screw and takes about five minutes. No calibration is required.
Conversation Summary
The owner of a 2015 Chevrolet Malibu has cabin heat but no heat to the windshield and asked where the blend door actuator is. The expert said the symptom points to the mode door actuator, located on the driver's side and accessible under the left dash without dashboard removal. A linked video was for the passenger-side blend door on a 2011 and does not apply. The left floor air outlet duct is removed with a clip or small screw in about five minutes, and no calibration is needed.
