Well, there is no way I have the right part.
While I was taking off the old silver bracket I noticed a third door that that original white piece attached to and controlled.
Back to the drawing board!
SPONSORED LINKS
Sunday, May 27th, 2018 AT 1:55 PM
MECHANIC
What is the part number of the actuator you have?
Sunday, May 27th, 2018 AT 3:14 PM
ALAN MCLEAN
MEMBER
OEM. 971542E200
Sunday, May 27th, 2018 AT 5:48 PM
MECHANIC
Let me check.
Sunday, May 27th, 2018 AT 5:49 PM
MECHANIC
Manual or auto climate control?
SPONSORED LINKS
Sunday, May 27th, 2018 AT 5:52 PM
ALAN MCLEAN
MEMBER
Manual.
Sunday, May 27th, 2018 AT 6:12 PM
STEVE W.
MECHANIC
The new actuator you have needs the plastic piece and the metal bracket removed then it will snap over the piece on the car and the screws will hold it to the bracket that is already there. They use the same actuator on the automatic and manual systems and the same unit fits on other vehicles as well. They sent you one that has "extra" parts that need to come off to be used in your application, that way they just stock one part instead of having five different versions that use the same actuator. The one you have is set up for the 2005-2006 that likes to shear the pins on the plastic arms.
Tuesday, May 29th, 2018 AT 10:24 AM
ALAN MCLEAN
MEMBER
Okay, thanks I appreciate the help. I will see if I can get that white plastic piece off, and the metal bracket which should be easy because that is just screwed in.
Tuesday, May 29th, 2018 AT 11:12 AM
STEVE W.
MECHANIC
The plastic will have a tab that snaps into the inner part of the actuator. Normally you can just use a small flat screwdriver to move the tab and it will come out.
Tuesday, May 29th, 2018 AT 12:43 PM
MARK.VANCE
MEMBER
Can u help me with mine I have a 07 Toyota Camry and trying to find were the actuator door is located
Saturday, March 9th, 2019 AT 8:13 PM
MECHANIC
You need to start a new question from the beginning. We will be glad to help you.
