Black smoke from the exhaust
200,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
GOKSY
I noticed the check engine light come on, the car began to use more gasoline than before, bringing out black smoke and i visited a mechanic. He said i should change the Electrical Control Unit, which i did, but the light was still on. i changed the injector fuel sprayers and the MAP sensor too, but the light is still on. i changed the ECU again, the light went off but black smoke is still coming out of the exhaust. I have tried to check if the car has any Oxygen Sensor, but could not find.
What can i do?
Jun 17, 2020 at 2:56 PM
JIS001
  • 3,412 POSTS
Hi Goksy. Can you post the trouble codes you got from the check engine light? That should give us a clue to better guide you.
Jun 17, 2020 at 3:14 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Having the trouble codes would help more in diagnosing your black smoke issue.If you don't have access to a code reader or scanner most local auto parts stores have a tool loaner program and can rent you one.Here is a tutorial showing what is involved for reading codes:
Also, Some places like AutoZone auto parts will check codes for free.Hope this helps and thanks for using 2carPros.
Jun 17, 2020 at 3:21 PM
  • 55,682 POSTS
This guide can help as well:
https://www.2carpros.com/articles/engine-black-smoke
Jun 18, 2020 at 5:13 AM
