beat knock on exhaust when I accelerate
289,500 MILES • 1.6L • 6 CYL • TURBO • 4WD • MANUAL
MXOLISI
  • 6 POSTS
Helo igot the problem with my car everything is in good condition, the problem is when I accelerate it got a beat knock on exhaust,and it getting some little smoke how can I stop this cause I serviced last week, sometimes it doesn't have a power please help Thank You
Oct 9, 2014 at 3:02 PM
  • 110,248 POSTS
Beat knock on exhaust... Can you explain?
Oct 16, 2014 at 12:38 PM
MXOLISI
  • 6 POSTS
Its like is busting,and it doesn't have power ,when I acceralate it smoking... Alot
Oct 16, 2014 at 2:22 PM
  • 110,248 POSTS
Where is the smoke coming from, what color is it, have you checked the catalytic converter to make sure it isn't loose inside?
Oct 17, 2014 at 10:31 AM
MXOLISI
  • 6 POSTS
Its coming from exhaust.. Its always smoking Blue
Oct 17, 2014 at 10:36 AM
MXOLISI
  • 6 POSTS
Its Blue... And its always smoking and its burning the fourth plugs.
Oct 17, 2014 at 10:39 AM
  • 110,248 POSTS
If it is blue, then oil is burning. Listen, if this is the original engine / miles, chances are the #4 cylinder is low on compression due to an issue with rings. As a result, burning oil and fouling the plug and causing a misfire and power loss. Chances are that the oil burning has damaged the catalytic converter. If the mileage is correct, I recommend checking engine compression.
Oct 17, 2014 at 10:45 AM
MXOLISI
  • 6 POSTS
Eish!! But my mechenic isi suspecting pistons bearings rings.. So if I may ask what is needed to be repair ???
Oct 17, 2014 at 11:08 AM
  • 110,248 POSTS
Before anything is done, you should check engine compression to confirm that is the problem. As far as your mechanic, I think you are a little confused. Most likely, he said to replace piston rings and while they are out, replace connecting rod bearing and main bearing in the engine.
Oct 17, 2014 at 11:57 AM
MXOLISI
  • 6 POSTS
OK this can stop my car smoking?
Oct 17, 2014 at 12:23 PM
  • 110,248 POSTS
checking engine compression won't stop the problem. It will determine if you need piston rings. Replacing rings and bearings is an expensive job, and I just want to know if that needs done before you spend that kind of money.
Oct 18, 2014 at 9:39 AM
