2003 Hyundai Elantra knock in front wheel
2003 HYUNDAI ELANTRA
97,000 MILES • 4 CYL • 2WD • AUTOMATIC
BLUESLADY
My car has a knock in the front drivers wheel when I brake. When driving, there's also a small wobble that seems to be getting a bit worse. Any ideas? Thank you..
Dec 20, 2008 at 3:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like worn wheel bearings. Raise and support vehicle, try "wiggling" the wheel . If it has play in it, then suspect worn wheel bearings or worn ball joint. I recommend servicing ASAP as this could lead to an accident if completely fails while driving.
Dec 20, 2008 at 4:20 AM
