BCM location
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
BARRY ESTES
Where is the BCM located? What is the labor hours to replace it?Thank you.
May 22, 2018 at 5:40 AM
Okay.
The body control module is part of the TIPM or the main fuse block under the hood.
I pays 1.7 hours to replace.
Removal:
1. Open hood.
2. Disconnect and isolate the battery negative cable.
3. Release the Totally Integrated Power Module (TIPM) cover retaining clips and open the TIPM cover.
4. Remove the TIPM positive cable retaining nut and remove the cable from the stud.
5. Depress the four mounting clips to disengage and remove the TIPM housing from its mounting bracket.
6. Disconnect each of the seven TIPM wire harness connectors.
7. Remove the TIPM from the vehicle.
May 22, 2018 at 7:48 AM
BARRY ESTES
May 22, 2018 at 7:30 PM
You are welcome.
Keep us posted.
May 22, 2018 at 7:48 PM
