battery light car will not start
202,000 MILES • 4 CYL • FWD • AUTOMATIC
TDHASTY
the battery light came on this morning, awhile after that the car startred losing power, when I stopped and turned off the car, it did not start again, got barely a crank out of it, noticed that the speedometer needle stopped working as I was driving also
Nov 5, 2015 at 3:37 AM
CARADIODOC
  • 34,414 POSTS
The "Battery" warning light means the battery is not being recharged while you're driving. If the battery is in good shape, that can give you up to an hour to get to a repair shop before the battery runs dead. Less time if you use a lot of electrical stuff like the head lights, heater fan, radio, and wipers. If you just keep on driving, the battery is going to run dead very quickly.
At this point a jump-start will get the engine started, but you need to use a portable charger to charge the battery at a slow rate for an hour or two, then have the charging system tested. The main suspect is a failed generator.
Nov 5, 2015 at 6:31 AM
