Will not start, possible battery issue
200,000 MILES • V8 • 2WD • AUTOMATIC
MAX13722
The van won't start without a jump. It runs fine once it has been jumped and can drive for a long time. It has shut off once or twice though while driving and requires a jump to restart when it does.
Jun 11, 2022 at 10:41 PM
CARADIODOC
  • 34,391 POSTS
You're describing a defective battery, but it is also possible for the charging system to be developing exactly one third of its maximum capacity. That can be enough at times to keep the engine running while having not enough extra capacity to recharge the battery after starting. Here's links to some related articles:
https://www.2carpros.com/articles/how-a-car-battery-works
https://www.2carpros.com/articles/how-to-replace-a-car-battery
The last one shows how to start the charging system test on your own, but if this turns out okay, it only means it is okay to continue on with the rest of the tests. That requires a professional charging system tester. I can describe that in more detail if it comes to that. Most places that sell replacement batteries can test your old one first, and just about all independent repair shops can complete the tests on the charging system.
Let me know if this helps or if you need more information.
Jun 12, 2022 at 4:54 AM
MAX13722
Thank you. It did end up being the battery, even though one place "tested it" and said it was good. I replaced it and the problem was solved. Thanks again.
Jun 14, 2022 at 1:34 AM
CARADIODOC
  • 34,391 POSTS
Dandy. Please come back to see us again with your next problem.
Jun 14, 2022 at 10:34 AM
