Bad idle
1997 NISSAN HARDBODY
150,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
17LJOHNSON
So here is the story, one night I was driving down a hill kind of fast and did not know that there was train tracks at the bottom and I hit them fast and hard and it bounced my truck pretty bad, right after the tracks it shut off and I had to pull over and it had a hard time starting right back up. after it started it had a bad idle. it fluctuates between 400 and 1000 rpm's, but does not fluctuate at all while driving only at idle. I have replaced my air idle control valve, all my vacuum lines, and also my spark plugs and spark plug wires. I am still in high school and work part time so I do not have enough money to keep throwing at it. if anyone has any idea what it could be I would really appreciate the help!
Apr 10, 2017 at 1:40 PM
  • 55,433 POSTS
It sounds like you have torn your air intake boot in the flight. Here is a guide to help you check for the problem.
https://www.2carpros.com/articles/replace-an-air-intake-boot
Please run this test and get back to us so we can continue helping you.
Best, Ken
Apr 11, 2017 at 9:20 AM
