Won't start been sitting for 6 years bad fuel what do I do
Nov 2, 2026 at 5:01 PM
✓Experienced Mechanic
Yep, you will need to remove the fuel tank and the fuel pump to flush the tank, replace the fuel filter and add fresh gasoline. Inspect the fuel hoses and connections for leaks. Here is how to drain the fuel out before removing the tank.
