B1201 U0256 trouble codes
2009 FORD ESCAPE
70,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
GIGISULAMANIDZE1
  • 88 POSTS
Hi, today i found two trouble codes. no idea how fix. every thing works fine but scanner showing :
U0256 - Lost Communication With Front Controls Interface Module 'A'.
B1201 steering wheel audio switch pack 2.
Jan 2, 2019 at 1:03 AM
Good morning,
The 1201 is about your audio controls on the steering wheel. the most common failure for this issue is the clock spring under the steering wheel.
The U code, do you have navigation?
Information and Entertainment System
Pinpoint Tests
Pinpoint Test F: The Steering Wheel Controls Are Inoperative/Do Not Operate Correctly
Refer to Wiring Diagram Set 130 (Escape/Mariner, Escape Hybrid/Mariner Hybrid), Audio/Navigation for schematic and connector information. See: Vehicle > Electrical > Diagrams By Number
Normal Operation
There are 4 different steering wheel controls configurations:
- Non-navigation, without the SYNC system
- VOL-, VOL+, SEEK-, SEEK+, MEDIA
- All switches are wired to the Audio Control Module (ACM).
- Non-navigation, with the SYNC system
- VOL-, VOL+, SEEK-, SEEK+, VOICE, MEDIA, PHONE, OK
- The VOL-, VOL+, SEEK-, and SEEK+ switches are wired to the ACM. The remaining switches are wired to the Accessory Protocol Interface Module (APIM).
- Navigation, without the SYNC system
- All switches are wired to the ACM.
- Navigation, with the SYNC system
Voltage is sent from the APIM (or ACM) to the steering wheel controls, and the same module grounds the return circuit. The VOL-, VOL+, SEEK-, and SEEK+ switches share signal and return circuits, while the VOICE, MEDIA, PHONE, and OK switches share separate signal and return circuits.
For all configurations, when a switch is pressed, the voltage is routed through a specific resistor value for each function. The ACM (or APIM) then uses the reference voltage to determine which control input function has been selected.
B11BA:1C-B2404
This pinpoint test is intended to diagnose the following:
- Wiring, terminals or connectors
- Clockspring
- Steering wheel controls
- ACM
- APIM
PINPOINT TEST F: THE STEERING WHEEL CONTROLS ARE INOPERATIVE/DO NOT OPERATE CORRECTLY
NOTICE: Use the correct probe adapter(s) when making measurements. Failure to use the correct probe adapter(s) may damage the connector.
F1 DETERMINE THE INOPERATIVE STEERING WHEEL CONTROLS
- Determine which steering wheel controls are inoperative by pressing each steering wheel control switch individually while operating the audio system in various modes (AM/FM, SYNC (if equipped), etc.).
- Is the concern with the VOL-, VOL+, SEEK-, SEEK+, or MEDIA switch?
GO to F2.
GO to F3.
F2 MONITOR THE STEERING WHEEL CONTROL PIDs (EXCEPT NAVIGATION/SYNC SWITCHES)
- Enter the following diagnostic mode on the scan tool: ACM DataLogger.
- Monitor the steering wheel controls PIDs while pressing each steering wheel controls switch as follows:
Jan 3, 2019 at 6:49 AM
GIGISULAMANIDZE1
  • 88 POSTS
Hi, thank you for answer. my car has Navigation, with the SYNC system all buttons work fine, every thing works fine.
Jan 3, 2019 at 6:59 AM
Are these active codes or inactive codes? the PCM have log term memory and still show the code but inactive.
Jan 3, 2019 at 7:02 AM
GIGISULAMANIDZE1
  • 88 POSTS
i have forscan when i removing codes they still appear.
Jan 3, 2019 at 7:03 AM
Okay, they are active. it is an electrical fault if they come right back. it may be the clock spring but you need to get it confirmed to be sure.
Jan 3, 2019 at 4:42 PM
GIGISULAMANIDZE1
  • 88 POSTS
How can i check if it is working properly?
Jan 3, 2019 at 10:13 PM
You will need an advanced scan tool to monitor the live data of the switches.
do you have an advanced scan tool?
Jan 4, 2019 at 3:28 AM
GIGISULAMANIDZE1
  • 88 POSTS
Yes, i have Forscan diagnostic tool, i checked live data and all buttons reacts when i press.
Jan 4, 2019 at 6:22 AM
Okay, then follow the diagnostic I posted in the beginning.
Jan 4, 2019 at 6:24 AM
GIGISULAMANIDZE1
  • 88 POSTS
Hi, can you show me where ACM-APIM are located ?
Jan 5, 2019 at 8:32 AM
That is a data logger, you cannot replace that. it is part of your scan tool, BCM, PCM and all the other modules.
Jan 5, 2019 at 8:55 AM
