[quote:08eb9527e6="grandpanorm"]Electrical problem
2001 Ford Escape 6 cyl Four Wheel Drive Automatic 120,00 miles
Can't get the ignition switch to turn from the lock position. Also steering is locked.[/quote:08eb9527e6]
Had no luck with the turning the wheel process. In
case someone else should ask, maybe this will work
for them. I just lightly tapped the key head 5 or 6
times with a screwdriver handle. The key then
turned easily.
Feb 6, 2009 at 5:21 AM
