Axle rebuild
JASONPYZO
  • 87 POSTS
I was wondering if you could tell me when replacing the shackles and all the bushings on the rear suspension, when fitting it all back up I have a tool box on the truck bed and the whole back on the inside of the extended cab is loaded with tools should I take then out when I put the tires back on and set it on the ground to tighten the suspension? Also should the shocks be on or off?
Sunday, September 11th, 2016 AT 9:04 AM
HMAC300
  • 48,601 POSTS
Jack the truck up and put jackstands on frame so weight is off spings, put shackles /springs/shocks on and let it down
Sunday, September 11th, 2016 AT 12:47 PM
