2002 Pontiac Grand Am ABS Lights
2002 AUDI
NDEN
I have a 2002 Grand Am 3.4L with 100,000 km. While driving the other day the service engine soon light and the ABS light and the Trac light all came on at once with the audilble alarm sounding. Every now and then I can get the lights to go off by turning the ignition key off and restarting. I tried retrieving codes with my Mac ProCode OBD II code reader but there are no codes coming up. It displays PASS as if no codes were detected yet the 3 lights are all on.
Any suggestions?
Apr 1, 2007 at 8:52 AM
SERVICE WRITER
  • 9,123 POSTS
Typically when the 3 lights come on, it most often turns out to be a front wheel speed sensor that usually comes with the bearing/hub.
Apr 1, 2007 at 1:44 PM
Suggested Repair
Inspect the front wheel speed sensor, which commonly fails with the wheel bearing and hub assembly when the service engine, ABS, and traction lights come on together.
Conversation Summary
A 2002 Pontiac Grand Am 3.4L showed the service engine soon, ABS, and traction lights with an audible alarm. Restarting sometimes cleared the lights, and an OBD-II reader reported no codes. The expert said this pattern most often indicates a failed front wheel speed sensor, usually supplied with the bearing and hub.
