Grand AM SE 1999 Wheel Hub Assy / ABS problem
GRANDAMMAN
My 99 SE 3.4 V6 has a problem with the front brakes. it was scanned 3 times and it was the RF wheell bearing (bad sensor) I thought this was odd to have 3 defect (Precision Brand) wheel hubs but then at a local Tuffy Center they replaced it with a Timken bearing and I still have the same results. the guy then tells me that its possible that when i drive the voltage in the the ECBM is dropping from 14.3 to about 2 volts and thats why the ABS light keeps coming on. Also when it starts from a cold start I back out ..I keep getting the LOW TRACTION light then the right side makes a scraping noise then the TRAC OFF and ABS lights appear for th rest of my trip. HELP!!!!!!!!!!!!!!
Jul 12, 2007 at 5:35 AM
SERVICE WRITER
  • 9,123 POSTS
Look at the wiring harness going to sensor very carefully for damage, is where I would go with this one. They can be sneaky like that.
What codes are listed in the computer, I am assuming it is the one for that wheel.
Jul 12, 2007 at 6:11 AM
