1997 Audi Cabriolet replacing the radiator
95,500 MILES • 6 CYL • 2WD • AUTOMATIC
BMWBOY
I noticed some antifreeze on my drive way I took a fast look , there appeared to be a leak from my radiator [some light green water stains along the sideof radiator] How difficult is it to replace? I have tools and some mechanical skill .
Thank You, AL
Jan 23, 2009 at 3:15 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Not a bad job drain lower left remove cooling fan the rad. Trans cooling lines hoses. Open bleed screws at heater hose by bulk head and on pipe runnning across front engine.
Jan 24, 2009 at 3:22 AM
