1997 Audi Cabriolet Fans not coming on!
1997 AUDI CABRIOLET
125,000 MILES • 6 CYL • FWD • AUTOMATIC
LDIKUN
  • 6 POSTS
Is it possible that if my thermostat is stuck, could this cause the fans to not come on. If so, where is the thermostat physically located as I do not have a manual for the car. I checked all the fuses and they are good. If it is a relay that possibley failed where that coils of the relay is opened, which relay number(s) are they.
Thanks for your help,
Lance
Aug 13, 2009 at 4:20 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check the cooling fan relay as well as the cooling fan control relay. fan relay is located on the main fuse / relay panel, position #11. fan control relay is located on the front auxiliary relay panel, position #18
Aug 13, 2009 at 5:26 AM
