1996 Audi A6 Won't Crank
IVIULLIN
1996 Audi A6 2.7L Quattro 126K. My car was working fine until i stopped and when i turned the key to start it again it turned to the start position and only all of the auxillary functions would work and the car would not even start to turn over. brought it to a local place and they don't seem to know what theyre doing. thanks
Oct 9, 2007 at 12:33 PM
  • 75,988 POSTS
If you see the normal lights that usually comes On-sounds like the starter circuit is not working in the ignition switch,transmission range switch, or the starter itself.
Look for power at the solenoid wire at starter while key at the cranking position of the ignition switch-Do you have power? no power there check at the TRS-power there-either you have a bad TRS or an open wire to the starter solenoid. No power its coming from the ignition switch.
Oct 9, 2007 at 12:51 PM
Suggested Repair
Check for power at the starter solenoid wire with the key in the crank position. If there is no power, check the transmission range switch: power there indicates a bad range switch or an open wire to the starter solenoid, while no power points to the ignition switch.
Conversation Summary
The owner of a 1996 Audi A6 says the car ran normally, then would not crank after a stop even though the key reached the start position and the accessories still worked. The expert says the starter circuit may be at fault in the ignition switch, transmission range switch, or starter, and recommends checking power at the starter solenoid and then at the range switch.
