Audi A6 Cooling System Won't Bleed
ZDRAGON88
I recently had to change, rather fix my oil cooler gasket, atleast thats what i think it is,any there are 2 antifreeze lines that go to it. well I had to take them off, witch yea great, dandy, did that fixed the problem. BUT now I dont know how to bleed the antifreeze system, and get out all the air pockets.
and it doesn't seem to work trying to do it the traditional way. just putting antifreeze in, leaving the cap off and starting it.
Please Help! thanks
Feb 27, 2007 at 2:50 PM
BRUCE HUNT
  • 3,754 POSTS
Technically when the system is refilled the bleeder is opened before the car is started. But the bleeder should be on the top hose off the radiator. You probably won't see much air being released but try it with the engine warm and running while taking care to open it slowly.
Feb 28, 2007 at 6:17 AM
Suggested Repair
When refilling, open the bleeder on the top radiator hose before starting the engine. Then, with the engine warm and running, open the bleeder slowly to release remaining air. Little visible air is normal.
Conversation Summary
The owner of an Audi A6 Quattro 2.8 V6 removed two coolant lines while repairing an oil cooler gasket and cannot purge air pockets by filling the system with the cap off and running the engine. The expert says the bleeder on the top radiator hose should be opened before startup, then opened slowly with the engine warm and running.
