2001 Audi A6 OXYGEN SENSORS
2001 AUDI A6
114,000 MILES • 6 CYL • 4WD • AUTOMATIC
YUALREADYNOE
FIRST TIME HERE GUYS ..BUT I HAVE A PROBLEM WITH MY AUDI
IT KEEPS GIVING ME THE CHECK ENGINE SIGN MY MECHANIC SAID I NEED TO GET A BED SENSOR OR A CENTER SENSOR SOMETHING LIKE THAT .. WHICH ONE DO YOU SUGEST THAT I COULD ORDER ONLINE AND GET IT DONE FROM HIM .. PLEASE HELP AND ALSO MY CAR IS TAKING TOO MUCH OIL AND GIVES LESS MILEAGE ..DOES THAT HAVE ANYTHING TO DO WITH THE SENSORS?
AND A QUESTION NOT RELATING TO THE SENSORS ..
I WANT MORE ACCELRATION FROM THIS CAR SINCE ITS A 2.7 TURBO CHARGED .. CAN SOMEONE HELP ME .. AND TELL ME HOW CAN I GET THE MOSTTT I MEAN MOSTT ACCELARATION OUT OF THIS CAR . WHAT DO I HAVE TO DO .. THANKS A LOTT LOT GUYS.
Oct 16, 2008 at 6:04 PM
KERENSELF
  • 54 POSTS
Hi!
Okay, first priority is to get it running properly. Take it to the local parts store and get them to give you a list of the troublecodes that are present. Most of them do this for free. At that point we can help you figure out what sensor you may need.
Next, let's get some more info about the oil usage. Do you see any evidence of leaking? Are there spots on the ground where you park or is there an oily coating on the bottom of the engine and/or any surfaces behind it? If so, the leak should be easily located. If you don't see any external leakage, I would start by replacing the PCV valve. If it is stopped up, there could be enough crankcase pressure to blow a little oil into your combustion chambers which would then burn - sometimes you'll see smoke coming out of the tailpipe.....
Once the functionality issues are addressed, the way is free and clear to improve performance.
Thanks!
Oct 16, 2008 at 9:27 PM
YUALREADYNOE
well he said that it needs a center oxygen sensor so your answer didnt help much .. i needed to kow which oxygen sensor i should get for the audi and where online can i order it .. and also there is a way to get more accelration from the car and theses sesnor or the valve doesnt affect it .. how can i get it modified to get more pick up from it .. let me know thanks a lot.
once again ..
oxygen senor bed or center
which brand
wherer online the best and cheapest
how to get moree pick and how to gety it modified to do that ! ??
thanks
Oct 17, 2008 at 6:29 AM
