need help audi a6 quatro 2.7 turbo
AUDI A6
PEPINOSTAR
my car start normally runs good untill the point of normall heat,suddenly it turns off by it self,no overheat, the gauges are fine, is just off,no engine check light, the car wont start unless i let it get could enough,with an hour the car will start like normal like nothing is wrong but,when it got normall hot,will go off again what it can be??? please help me
Sep 8, 2007 at 11:57 AM
14FOREST
  • 9 POSTS
Look on top of the air box. You will see 2 ignition modules. Take them off and clean the surfaces. Go to radio shack and get the silver heat transfer grease. Apply it to both surfaces. It cost $10 and might fix your problem if the ignition modules are heating up.
Sep 30, 2007 at 9:30 AM
