2001 Audi A6 Timing Belt Cost
POU
2001 Audi a6 2.7 T mileage at 89000
Approximately how much should it cost to replace timing belt assuming you also replace water pump, tensioners etc.? Is it necessary to have special tools? Is it necessary to remove front bumper? Is it necessary to repleace water pump and pulleys? :?:
Jul 10, 2007 at 5:05 AM
2CARPRO JACK
  • 11,533 POSTS
You are probably looking at anywhere between 800 and 1000 dollars depending on the hourly rate of the shop and if all tensioners and idlers are replaced. My software mentions a few specialty alignment tools req'd to hold th ecams and crank in alignment, and it also says that removing the bumper is req'd
Jul 11, 2007 at 7:10 AM
Suggested Repair
Budget about $800 to $1000 for the timing belt job, depending on the shop labor rate and whether all tensioners and idlers are replaced. Specialty tools are required to hold the cams and crank in alignment, and the front bumper must be removed.
Conversation Summary
The owner of a 2001 Audi A6 2.7T with 89,000 miles asked about timing belt replacement cost when also replacing the water pump, tensioners, and related parts, and whether special tools, bumper removal, and water pump or pulley replacement are necessary. The expert estimated $800 to $1000 depending on labor rate and whether all tensioners and idlers are replaced, and said specialty cam and crank alignment tools and front bumper removal are required.
