1999 Audi A6 Brake Light Stays On
RENEMH88
i have an audi with 154K miles on it. the "brake light" warning is coming up on the dash and the third brake light in the back windshield is staying on. also, when the brakes are pressed, the passenger side parking light comes in, but goes off when brake is released. any ideas? thanks.
Mar 16, 2007 at 2:38 PM
MERLIN2021
  • 17,250 POSTS
as for the cyclops pull up on the brake pedal, the stop light switch is missadjusted or needs to be replaced. The other lights? Check your pads they have wear sensors on them.
Mar 26, 2007 at 2:52 AM
Suggested Repair
Pull up on the brake pedal and adjust or replace the stop light switch if the third brake light stays on. Also inspect the brake pads, which have wear sensors, for the dash warning and related lighting issues.
Conversation Summary
The owner of a 1999 Audi A6 Quattro with 154,000 miles reports a dash brake-light warning, a third brake light that stays on, and the passenger parking light illuminating when the brake pedal is pressed. The expert says the stop light switch is misadjusted or needs replacement and recommends checking the brake pads and their wear sensors.
