1999 Audi A6 Fuel Fill Cuts Off
JOHNPARKER
I have a 99 audi a6 2.8L 30V with 100k miles on it.
2 symptoms suddenly appeared.
1) there is a whine that comes and goes from somewhere in the back of the car.
2) when i try to fill the car up, i get about 5 gallons in the tank, and it cuts off, with some air and fuell spraying back out of the nozzle.
Are these related? Is there a simple fix?
any thoughts would be appreciated
Oct 19, 2007 at 5:40 PM
  • 75,988 POSTS
You need to the have Evaporative system check, Could be a problem with the purging solenoid,charcoal canister,plugged vent lines and liquid/vapor seperator-Your system is not being purge it has excessive pressure. Could be very well be your gas cap.
Oct 19, 2007 at 9:55 PM
Suggested Repair
Have the evaporative emissions system checked. Possible causes include a faulty purge solenoid, charcoal canister, plugged vent lines, liquid/vapor separator, or a bad gas cap causing excessive tank pressure.
Conversation Summary
The owner of a 1999 Audi A6 2.8 reports an intermittent rear whine and fuel-nozzle shutoff after about five gallons, with fuel and air spraying back. The expert says the EVAP system may not be purging and causing excess pressure, and recommends checking the purge solenoid, charcoal canister, vent lines, liquid/vapor separator, and gas cap.
