1997 Audi A6 Power Steering Pump Whine
FIREMANDAVE
I have been told that I need a new power steering pump. Is this hard to replace? Any advice regarding rebuilt pumps? The vehicle had 125k miles
Jan 19, 2007 at 10:12 AM
BRUCE HUNT
  • 3,754 POSTS
No, it is not hard to replace, if you know what you are doing or have a repair manual to guide you through it.
Rebuilts from a reputable parts place will probably be fine.
You have been told and what lead them to come to that conclusion? Just curious.
Jan 23, 2007 at 7:00 AM
FIREMANDAVE
There was a whinning noise periodically coming from the engine. They said it was coming from the ps pump.
Jan 23, 2007 at 11:47 AM
Suggested Repair
If comfortable with the job or using a repair manual, replace the power steering pump. A rebuilt pump from a reputable parts supplier is generally acceptable. Confirm the periodic whine is actually coming from the pump before replacing it.
Conversation Summary
The owner of a 1997 Audi A6 Quattro with 125,000 miles was told the power steering pump needed replacement and asked how difficult the job is and whether a rebuilt pump is acceptable. An expert said replacement is not hard with experience or a repair manual, that a rebuilt unit from a reputable source should be fine, and asked what led to the diagnosis. The owner reported a periodic engine whine attributed to the power steering pump.
