1998 Audi A4 Lacks Power
AUDI-GUY
Hi, i have audi a4 1998 2.8 v6 30v quatrro and it's manual. my car starts jerking at 1500 rpm and the rpm slwos down and it always lacks power. when i drive i have to press the gas pedal all the way to the floor to make the car start to move. i changed the gas filter already but that din't help. i went to this one place where they checked my computer and the code told me that there is a "throttle position malfunction" problem and also the check engine light is on and somtimes the car starts jerking while it's idiling and the check engine light flashs. also i have to start my car a couple of times to make it idle by itself. another thing is that i have to be in 5th gear to drive normaly on the highway. please respond as soon as possible :?:[b:fb40703e45][/b:fb40703e45]
Mar 7, 2006 at 2:52 PM
PEPPERMRJ
  • 1,158 POSTS
Sounds like you need to replace the throttle position sensor or check it's wiring, connection, and function.
Good luck and let us know. :)
Mar 10, 2006 at 10:48 AM
LAURENCE
  • 7 POSTS
Hey,
I had a similar problem. Perhaps its not the same on. Anyways, here is it: Car was trembling, and lost complete power. Check engine light was on. All I had to do was to change my coil packs.
$60 in repair. Works fine now. I received a letter 2 months ago from Audi saying this was a typical problem and were having recalls on this one.
L.
Jan 19, 2010 at 5:06 AM
Suggested Repair
Test and likely replace the throttle position sensor, and inspect its wiring, connector, and function. A scan showed a throttle position malfunction.
Conversation Summary
A 1998 Audi A4 2.8 V6 Quattro manual lacks power, jerks around 1500 rpm, sometimes jerks at idle with a flashing check engine light, and is hard to keep idling. Full throttle is needed to get moving, and a fuel filter replacement did not help. A scan reported a throttle position malfunction. The expert advised replacing the throttle position sensor or checking its wiring, connection, and function. Another owner reported a similar power-loss issue fixed by replacing coil packs after an Audi recall notice.
