2001 Audi A4 Oil Consumption
WILDGEESE
I have a 2001 A4 Quatro 2.8. I bought it new and and it burns 1Qt oil/3000 miles since new. It now has 77,000 miles on it and is running fine otherwise.
I have never owned a vehicle that burned any oil between 3000/ mile oil changes. Some have had 150K plus miles.
I have called every Audi Dealership in my area and they all say the this engine "uses" oil and that my consumption rate is actually low for that engine. I love this car and plan on keeping it for a while and don't plan on having to replace an engine anytime soon.
Sould I be worrying? Any Audi Technical Service Bullitins on the 2.8?
Nov 11, 2007 at 3:45 PM
FISHERMAN
  • 937 POSTS
[quote:180f279988="wildgeese"]I have a 2001 A4 Quatro 2.8. I bought it new and and it burns 1Qt oil/3000 miles since new. It now has 77,000 miles on it and is running fine otherwise.
Sould I be worrying? Any Audi Technical Service Bullitins on the 2.8?[/quote:180f279988]
Hello !!
Well those engines have a high oil consuption (some of them are even worse) don`t worry about it just be carefull on the oil level and the schedule maintenance.
here the service bulletins:
Bulletins for 2001 Audi A4 2.8 Quattro Sedan V6-2771cc 2.8L DOHC (ATQ)
Service Bulletins
Audio System - Radio Code Retrieval
Lighting - Moisture Accumulation in Headlamps
Audio System - Radio Inoperative After Replacement
Fuel System - Idle Fluctuates or is Too Low
Instruments - Cluster/Illumination Configurations
Battery - Correct Din Specification Necessity
A/C - Fresh Air Control Lever Light Inoperative
Oil Cooler Hoses - Coolant Leak
Deployed Air Bag - Repair Warning
Navigation System - CD Release Versions/Usage
Engine - Hesitation/Lack of Power On Take Off
Rear Lid - Difficult to Open and Close or Sticks
Alloy Wheels - Cleaning
Paint - Swirl Mark/Fine Scratch Reduction
Airbag/Pyrotechnic Seatbelt - Deployment Inquiries
Child Restraint - Anchor Installation/Retrofitting
Engine - Cranks But Won't Start
Radio - Connector Replacement
Self Leveling System - Inoperative/Lamp ON/DTC's Set
Cellular Phone - Technical Support Helpline
Navigation System - Incorrect Distance Readings
Underbody Plugs - Wind Noise
Remote Transmitter - Intermittently Inoperative
Engine - Oil Capacity Chart
Vehicle - Fluid Capacity Chart
Maintenance - Schedule
Cell Phone - Serial Number Recording
Paint - Matte Finish Precautions
VIN Plate/Certification Label - Ordering Procedure
Radio - Removal & Installation Procedure
Warranty Claims - Conditions Requiring OTS Contact
Interior - Cleaning Tips
Leather Upholstery - Cleaning Procedures
Oxygen Sensor - Verifying Connections After Repairs
Windshield - Stress Crack/Distortion Survey
Nov 14, 2007 at 11:20 AM
DOCHAGERTY
  • 9,606 POSTS
1qt. in 3K miles would be within what the manufacturer considers normal. Having said that I feel your concern and when I tell my BMW customers that BMW considers 1.5qts in 1000 miles normal, I am greeted with less than a happy customer. I might suggest switching to a heavier viscosity lubricant and/or a different brand and see if that helps.
Nov 14, 2007 at 12:26 PM
Suggested Repair
Treat about 1 quart of oil every 3,000 miles as within the normal range reported for this engine. Keep the oil level checked and follow scheduled maintenance. A heavier viscosity and/or a different oil brand may reduce consumption.
Conversation Summary
The owner of a 2001 Audi A4 Quattro 2.8 reports burning about 1 quart of oil every 3,000 miles since new, with 77,000 miles and otherwise normal running. Dealers said this engine uses oil and that the rate is relatively low. Experts agreed the consumption is typical, advised monitoring the oil level and maintenance schedule, and suggested trying a heavier viscosity or different oil brand.
