Audi A3 Won't Start From Key
NIKK
I recently repaired a damaged Audi A3 TDI quattro s-line (170) - front OS was damaged along with the fuse box -
all body work is done and we have an electrician replaced fuse box and cabling. The car does have power ie windows, stereo. the remote key will lock and unlock the vehicle. and we can get the engine to turn over no probs.
but it will not start from the key, the dash isnt lighting up either?
Any Audi experts out there know what the problem might be? Thanks in advance for any help.
Nikk
Aug 15, 2007 at 5:05 AM
  • 55,781 POSTS
Hello, the best way to attack the problem is to purchase a wiring diagram and trace the wiring to see were the short circuit is located. It sounds like the ignition switch is not getting power on one of the polls on the ignition switch itself. Please go here to get your online manual and get back to me,, thanks for visiting 2carpros.com :D
Sep 2, 2007 at 4:25 AM
Suggested Repair
Obtain a wiring diagram and trace the ignition circuit for a short. The ignition switch may not be receiving power on one of its terminals.
Conversation Summary
The owner repaired a damaged Audi A3 TDI after front-end and fuse-box damage. After the fuse box and wiring were replaced, the car has power, locks with the remote, and cranks, but it will not start from the key and the dash does not light. The expert advises getting a wiring diagram and tracing for a short, suspecting the ignition switch is not getting power on one terminal.
