Alternator charging problems?
KHLOW2008
  • 41,814 POSTS
The charging system is not good if charging voltage drops drastically when electrical loads are applied. It could be the alternator or the crank pulley damaged harmonic damper, if equipped).
I do not believe the overcharging of the Freon is causing any problem to the charging circuit.
Friday, September 11th, 2020 AT 12:14 PM (Merged)
CFOSTER2030
Hi Brandon, I have the same exact problem you described. Did you find the problem yet? The mechanic here does not know a whole lot. Did you try taking it to a shop who has a real charging system tester like Autozone used to have? I am curious if the new alternator is actually putting out any amperage at all at this point. The voltages are good without the AC running but I do not know if any real amperage is getting to the battery to charge it. I was thinking something is grounding out somewhere once the cooling circuit is engaged. Please reply with any suggestions. Thanks.
RENEE L
  • ADMIN
  • 1,260 POSTS
Hello CFOSTER2030,
Please post your question here:
Be sure to include as much information as possible about your vehicle.
Make sure you are logged into the site.
One of our experts will be happy to assist you.
Thank you for using 2CarPro.com.
Renee
Admin
CFOSTER2030
  • 1998 LEXUS ES 300
  • 3.0L
  • 6 CYL
  • 162,000 MILES
It started with the surging of the headlights and blower fan motor. I then tested voltage at the battery while idling at 700 rpm voltage at 12.5. I then replaced the alternator because the battery was not very old. The new alternator did the exact same thing. At 1250 rpm with AC on and fan blowing on high voltage is at 14 volts. Same thing happens with rear window defroster (heavy load) at idle. Tested battery and was reading 10.5 volts. Replaced battery and continued to do the same thing. Without any load at idle it is at 14 volts. It seems under heavy electrical load at idle it cannot charge the battery. I replaced the ground wires and same thing still persists. The 100 amp fuse is good and the positive wire coming off the alternator is good as well. What could it be? Thanks.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Low charging like this is usually a engine block to chassis ground or negative battery to body ground that is missing. Can you locate and confirm there to major grounds are intact please?
Cheers, Ken
CFOSTER2030
Hello, thank you for your reply. I have replaced the block to battery and chassy to battery ground connection. They all meet at the negative battery post.
Even at 1000 rpm with AC on my voltage is around 13 or so. Not until around 1,300 does it get back to 14 volts. Thought maybe it was also running to low on the rpm's. With AC on its sits at 700.
My other thought was I burned out two alternators because the battery failed on the first maxing out the original alternator. Then I stick a brand new alternator in with a bad battery ruining it. Is this possibly too? Thanks for your help.
KEN L
  • 48,363 POSTS
Yes a bad battery can wipe out alternators no problem, I would replace the battery and the positive battery cable and get a warranty alternator. Is the alternator a Denso unit?
https://www.amazon.com/gp/product/B000C5UEA4/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=2carprcom-20&creative=9325&linkCode=as2&creativeASIN=B000C5UEA4&linkId=e515ea6539089ab8b97d1fe3a461b582
$117.00 on Amazon
JOE COLLIER
I have same problem I was wondering in you ever solved it or not. I tried all the same things my battery will die if I run my AC too long. I have brand new alternator and battery and upgraded all wires to zero gauge.
KEN L
  • 48,363 POSTS
I would check the ground from the battery to the engine and body, also did you use Denso? If not that can be the problem as well. Check out the link above.
