Bad alternator ruined the battery
106,000 MILES • 6 CYL
ANTHONY71
  • 9 POSTS
Apparently my alternator went bad and ruined the battery. I put a new battery in so I can roll up my windows. Don't have enough for a new alternator yet.so I tried to crank the motor and it just clicked and nothing. It won't even power the windows? Help?
Jul 10, 2019 at 6:39 AM
  • 110,248 POSTS
Welcome to 2CarPros.
If the starter only clicks, that usually indicates a weak battery. Since you just replaced it, it could need charged or it could be bad.
Try this simple load test and let me know the results. Also, if you have a charger, try charging it. Make sure the battery terminals are clean and tight also.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
Make sure you go through link 3. It discusses a similar symptom to what you are experiencing.
Jul 10, 2019 at 3:38 PM
ANTHONY71
  • 9 POSTS
Battery is brand new.when I turn the key to the on position, nothing comes on except the check engine light. Won't crank or even click. All hooked up properly.
Jul 10, 2019 at 9:30 PM
ANTHONY71
  • 9 POSTS
Would the bad alternator prevent the new battery to start the car or operate the electric windows? I'm bummed if there's an other electrical problem I'm not aware of.I don't have any testing equipment. If it's possible I purchased a dead battery from Wal-Mart, I have to take the battery to be tested on my bicycle. So if you could tell me your opinion on this matter, it's greatly appreciated.
Jul 11, 2019 at 1:41 AM
  • 110,248 POSTS
Welcome back:
Honestly, the alternator won't prevent the engine from starting if the battery is good. Did you check all of the main fuses under the hood?
When you turn the key to start the engine, does the check engine light dim? Does anything other work, such as the dome light, radio, headlights?
It's possible that the battery lost charge sitting on the shelf. It's unlikely but possible. you are certain that the battery terminals are clean and tight?
Let me know. Is there anyone that could try to jump start the vehicle with you?
Jul 11, 2019 at 12:44 PM
