1993 Volvo 850 GLT Service Light Reset
ALL OTHER MAKES ALL OTHER MODELS
MAI
My name is Mai, I own a 1993 850 GLT Volvo, like my other cars I usually like to perform maintenance and usually gather information before I even get started. I bought this car back in October and its due for maintenance. The Service light came on and I need to reset it after service is done, the question is, would I be able to do it, is there a switch to reset it or do I need to take it to the garage?
Feb 15, 2006 at 7:03 AM
PEPPERMRJ
  • 1,158 POSTS
Welcome to the forum. You should be able to reset the SRI (service reminder indicator light) by using the DLC (data link connector). It is located in the passenger side front of the engine compartment.
Turn the ignition to the on position.
Remove the cover to reveal the socket and button.
Install the diagnostic connector in socket 7.
Depress the button on the DLC 4 times.
When the light emmitting diode (LED) is lit the system is ready to be reset.
Depress the button once and wait for the LED to light again.
Depress the button 5 times and wait for the LED to light again.
Depress the button once again and wait for the LED to light again.
Turn the ignition off.
Reastart the engine to be sure The SRI is out.
If you need photos PM me.
Good luck. Post often and let us know how you make out. 8)
Feb 15, 2006 at 2:46 PM
Suggested Repair
Reset the service reminder indicator with the data link connector at the passenger-side front of the engine compartment. With the ignition on, install the diagnostic connector in socket 7, press the button four times until the LED lights, then press once, five times, and once more, waiting for the LED each time. Turn the ignition off and restart to confirm the light is out.
Conversation Summary
The owner of a 1993 Volvo 850 GLT asked whether the service light can be reset at home after maintenance or must be done at a garage. An expert explained that the service reminder indicator can be reset through the engine-compartment data link connector using socket 7 and a specific button and LED sequence.
