1996 Volvo 850 High NOx Emissions
TOOTSIE
1996 Volvo 850 GLT failed NO (PPM) test. Limits at 15 MPH are Max 430, Average 57. Measured at 534. Everything else passed otherwise. Mechanic replaced spark plugs & battery. He now wants to change the catalytic converter. Could this have been the problem? We have put quite a bit of money trying to get the darn car to pass smog already.
May 30, 2006 at 8:26 AM
2CARPRO JACK
  • 11,533 POSTS
Nox is exhaust temp.......... be sure the egr system works if so equipped...... if not could be a mixture problem(lean) try oxygen sensors the go to the Mass Air Flow Meter
Sep 12, 2006 at 10:35 AM
Suggested Repair
Before replacing the catalytic converter, verify the EGR system works if the car is equipped with one. If EGR is not the cause, check for a lean mixture by testing the oxygen sensors, then the mass airflow meter.
Conversation Summary
A 1996 Volvo 850 GLT failed the NOx portion of an emissions test at 15 MPH (534 PPM versus a 430 PPM limit) while other readings passed. Spark plugs and the battery were already replaced, and the mechanic proposed a catalytic converter. The expert said high NOx relates to exhaust temperature and advised confirming EGR operation if equipped, then checking for a lean mixture via the oxygen sensors and mass airflow meter.
