1991 Toyota 4Runner No Start
1991 ALL OTHER MAKES ALL OTHER MODELS
CAPRICE350
ran fine for 25 miles shut down no power i changed battery and ground cable good electrical power but wont start has spark and on time timing belt is good new fuel pump with intank screen and new filter new circuit opening relay for air valve and fuel pump also ecu changed out of a running 4runner of same to test no start just turns over good compression in engine its the v-6 air flow meter also replaced if you open the valve with your hand the fuel pump turns on all other fuses and relays test good with ohm meter please help
Nov 28, 2006 at 9:18 AM
BACKYARDMECHANIC
  • 337 POSTS
You have everthing to make the car run. Timing, spark , and fuel. If you have all so the above I have I feeling you may have fouled out the plugs from trying to start the car. You may have rerplaced the defected part a few parts ago but never realized it. (I've done this before) Sometimes the answer is so simple we look right over it.
Hope this helps Backyardmechanic :(
Dec 7, 2006 at 1:40 AM
Suggested Repair
Inspect and replace spark plugs that may be fouled from repeated start attempts, and recheck whether an earlier parts replacement already fixed the original fault.
Conversation Summary
A 1991 V6, described as the same as a 4Runner, shut down with no power after 25 miles and now only cranks. The owner replaced the battery, ground cable, fuel pump, filter, circuit opening relay, ECU, and airflow meter, and reports spark, correct timing, good compression, and a pump that runs when the air valve is opened by hand. The expert says the basics for running are present and suggests fouled plugs from repeated start attempts, or that an earlier repair already fixed the fault.
