2002 Grand Marquis fuel problem. No start
FORGETG
  • 2002 ALL OTHER MAKES ALL OTHER MODELS
Good day all. I am recently the proud owner of a 2002 grand marquis with a 4.6 liter engine. With a problem, I was told that the car sat for a month or two and now it turns over ok but does not start, I got a bit of gas and poured it down the (throttle body), car started ran a few then stopped.I checked the gas gauge and it said it was half full, I poured a gallon of gas into the tank and it went up to full, I then put a bit more in the (throttle body) it ran again for a few then stopped again.I was going to check the fuse for the fuel pump, but the car came with out a manual.I did pull the pump relay and swapped it out. Still no luck, my thoughts, the fuse or the pump?
Any help would be appreciated
Wednesday, March 7th, 2007 AT 7:06 AM
MERLIN2021
  • 17,250 POSTS
When you first turn the key to on not start, on within 5 sec see if you hear the pump in the gas tank, if you do try changing the filter. Then work on the big stuff. Sounds like the person you bought it from ain't totally honest! Let us know.
Wednesday, March 7th, 2007 AT 6:29 PM
FORGETG
Got the car from the in law. How honest, I am sure the info is correct, and the car has only 8000 orig miles on it, I just found out there is a Inertia Fuel Shutoff Switch, I am going to try this first then the 5 second pump.I will let you all know.
Thanks
Thursday, March 8th, 2007 AT 6:18 AM
MERLIN2021
  • 17,250 POSTS
Ok
Thursday, March 8th, 2007 AT 1:51 PM
