2002 F150 Super Crew crank but not starting
2002 ALL OTHER MAKES ALL OTHER MODELS
JGRAHAM
I have a 2002 F150 Super Crew 2x; 5.4L engine; 72000 miles; automatic trans with new battery.
After replacing the dead battery, I have experience cranking problem. The dash lights are out, odometer has green dash lines across it, anti theft light is blinking; and the truck will not start even though it is cranking.
I can wait until the odometer dash lines disappear, then I can try starting the truck... usually it will restart.
I had the engine/computer codes checked: no codes noted.
Any ideas what could be causing this?
Thanks.
Apr 19, 2007 at 8:33 AM
MERLIN2021
  • 17,250 POSTS
it sounds like you need to have Ford reflash the PCM
Apr 19, 2007 at 8:41 AM
JGRAHAM
[quote:ba77a1fb56="merlin2021"]it sounds like you need to have Ford reflash the PCM[/quote:ba77a1fb56]
Thank you for your response/assistance.
What is the PCM? How does this cause the issue I am experiencing? I have seen since I entered by question, a web note surrounding a similar issue by another, but someone told him that it was caused by the passive theft system/bus control bar.
I appreciate a short explanation of the PCM.
Thank you again.
Apr 20, 2007 at 2:06 AM
MERLIN2021
  • 17,250 POSTS
PCM is the Brains of the outfit!
Apr 20, 2007 at 10:26 AM
