2000 Mitsubishi Montero Stalls After Battery
2000 ALL OTHER MAKES ALL OTHER MODELS
DEW966
Today I changed the battery for the second time since I bought the vehicle. And for the second time it stalls after doing so. Last time I took it to the dealer and they told me they had to reset something. A sensor or a sensor reading I think was what they said at the time. Do you know what they did and is it something I can do myself so I don't have to have it towed to the dealer?
Aug 18, 2006 at 10:56 AM
BESTBET777
  • 89 POSTS
They are probably entering factory codes into the computer.
Apr 19, 2007 at 5:52 AM
TROMEL
When you replace or un-hook your battery in your Montero afted you replace it or re-connect it all you have to do is turn your ignition forward to aux and them press the gas pedal down all the was to the floor for a couple of seconds. This will re-set your throttle body reading and your Montero Sport will no longer die. :mrgreen:
Apr 30, 2007 at 7:43 AM
Suggested Repair
After reconnecting the battery, turn the ignition to accessory and press the accelerator fully to the floor for a couple of seconds to reset the throttle body reading. If stalling continues, a dealer may need to enter factory codes into the computer.
Conversation Summary
The owner of a 2000 Montero says the engine stalls after battery replacement, and a dealer previously reset a sensor or reading. One reply suggests the dealer entered factory codes. Another says turning the key to accessory and holding the gas pedal down for a few seconds resets the throttle body so the vehicle no longer dies.
