1992 Mitsubishi Montero Won't Start
1992 ALL OTHER MAKES ALL OTHER MODELS
CECILWLSN
I have a 1992 montero that is acting like it is out of fuel . I put in a new pump and filter . is there any thing else I can try . the car has spark and turns over but wont start back up . it has 205175 miles has the v6
Jan 16, 2007 at 3:09 PM
BRUCE HUNT
  • 3,754 POSTS
Happen all the time warm or cold engine?
Had any work done to the vehicle recently?
Just some quickies to look at. Check the coolant level of the vehicle. When engine warm, crack open slowly a bleeder to let out air in the cooling system. Check out engine for a vacuum line leaking or any vacuum leak.
Let us know.
Jan 17, 2007 at 2:45 AM
LORENZO
Yes- I''m currently waitng to replace a cracked radiator.
Jan 17, 2007 at 1:53 PM
BRUCE HUNT
  • 3,754 POSTS
In your exam of the coolant did you find a leak? A lower level of coolant will leave air in places where sensors are trying to determine the temp of the engine. They falsely read the temp and make improper adjustments of fuel and air. Make sense?
Jan 17, 2007 at 1:59 PM
LORENZO
Yes- There is at least one crack I was able to see( close to the top of radiator). Coolant would get hot and start to come out of the crack causing it to smoke. Coolant was leaking so it probably got low and started the irregular idle.
I'm replacing the Radiator and hopefulll this will cure the irregular idle.
Jan 18, 2007 at 1:48 AM
LORENZO
I also noticed the heat inside the car is not funtioning. Will replacing the Radiator cure this problem.
Jan 23, 2007 at 8:12 AM
BRUCE HUNT
  • 3,754 POSTS
I would be that ALL of the problems will disappear. The radiator is so simple yet so vital. You are constantly running on low coolant right now. Get it replaced and you will be happy.
Jan 24, 2007 at 2:55 AM
Suggested Repair
Replace the cracked radiator, refill the cooling system, and bleed out trapped air. Low coolant can make temperature sensors misread and disrupt fuel and air mixture, idle, and heater operation. Also inspect for vacuum leaks.
Conversation Summary
The owner of a 1992 Mitsubishi Montero with a V6 said it acted out of fuel, had spark, and cranked but would not restart after a new fuel pump and filter. The discussion then identified a cracked radiator, coolant loss, irregular idle, and no cabin heat. The expert explained that low coolant can leave air around temperature sensors and cause incorrect fuel and air adjustments, and advised replacing the radiator so the cooling system can be refilled and bled.
