2000 Intrepid EGR Valve Location
2000 ALL OTHER MAKES ALL OTHER MODELS
WILBER
  • 5 POSTS
Where exactly is the egr valve in the 2000 intrepid? Do I have to take off the manifold? I believe it to be under the pcv valve but not sure.
Thank you!
Feb 27, 2006 at 1:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
It is on the right side manifold. Remove the air intake plenum and the air filter housing to gain access to the EGR valve and tube.
Thanks for using 2CarPros.com!
Mar 12, 2009 at 8:26 PM
Suggested Repair
The EGR valve is on the right-side manifold. Remove the air intake plenum and the air filter housing to access the EGR valve and tube.
Conversation Summary
The owner asked where the EGR valve is on a 2000 Intrepid and whether the manifold must be removed, suspecting it was under the PCV valve. The expert said it is on the right-side manifold and that the air intake plenum and air filter housing must be removed to reach the EGR valve and tube.
