1993 Lumina PCV Valve Location
GMC
DEALER819
i have a 1993 lumina . Where is the pcv valve?
Feb 27, 2006 at 5:09 AM
JPAM
  • 307 POSTS
The PCV valve can be located in several places. The most common location is in a rubber grommet in the valve cover. It can be installed in the middle of the hose connections, as well as installed directly in the intake manifold. good luck..
Feb 27, 2006 at 5:17 PM
Suggested Repair
Look for the PCV valve in a rubber grommet in the valve cover, inline in the hose connections, or installed directly in the intake manifold.
Conversation Summary
The owner of a 1993 Lumina asked where the PCV valve is located. The expert said it is commonly found in a rubber grommet in the valve cover, in the middle of the hose connections, or installed directly in the intake manifold.
