1991 Suzuki Sidekick fuell problems.
MIKEBROWN1175
  • 1991 ALL OTHER MAKES ALL OTHER MODELS
Car died.
Fuel is getting to injector but injector has no power.
Noid light test performed at injector wiring (no power).
Wiring seems to be o.K.
Any ideas?
Wednesday, July 12th, 2006 AT 9:13 PM
KDIDDY
I'm told that this is a common problem with this model. I have one. The fix is either buy a new ECM ($150 to $350)or add a 14 awg wire from the hot side of the coil primary wiring plug to the red wire of the fuel timing pluggy thingy where you looked for and didn't find the 12VDC. Scotchlocks will work but I soldered mine as I have seen too many Scotchlocks corrode over time. Sadly I still have no spark so mine still sits. Good luck, k
Wednesday, September 27th, 2006 AT 1:07 AM
