1983 Questions for all other cars cAR WILL NOT START
JUAN QUINONES
  • 1983 ALL OTHER MAKES ALL OTHER MODELS
Electrical problem
1983 Questions for all other cars Front Wheel Drive Automatic 425000 miles
ve a 1983 chavy Cl
Friday, February 27th, 2009 AT 10:46 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, February 28th, 2009 AT 1:56 AM
Related Engine Not Running Content
