1977 International Scout II Traveler
SCHANCAC
  • 1977 ALL OTHER MAKES ALL OTHER MODELS
Hi there. My friend has a scout that has trouble cranking and when I do finally get it started it runs fine for about 5 minutes and will die in just a split second, like the ignition was turned off. No stumbling or anticipation of shutting down. It will then restart, run fine, and shut down again. He swears that a faulty starter will cause a vehicle to quit running, but I have never heard of this. I've dealt with a lot of bad starters before, and they would run fine, just wouldn't start well. Is this the case? I do think the starter is bad, but don't think it would cause it to quit. I already suspected and replaced the "Gold box" igntion module so I don't think that's the problem unless the new one is faulty. Fuel, plugs, wires, cap and rotor seem to be fine. Thanks, Hope you can help.
-Aaron Paia, HI
Thursday, November 22nd, 2007 AT 2:18 PM
Check the fuel pressure. Next time it dies don't touch the key-look for power immediately at the coil.
Thursday, November 22nd, 2007 AT 3:53 PM
BIGFRANKSSCOUT
Check the wiring going through the fire wall the plug on scouts is a bad design and sometimes builds corrosion and disconects power to coil and other parts.
Wednesday, May 25th, 2011 AT 6:08 PM
Related Engine Not Running Content
