Alarm activated
229,000 MILES
COBYSHOEMAKER21
  • 28 POSTS
I have a question regarding another 2001 Honda Civic I have. It is an automatic, the key flashes constantly on the dash. Which is the immobilizer, but from what I have researched, if that continues to flash, the car will not start. This car starts, but acts like it is in limp mode and cannot go over 45 mph.
Jan 17, 2019 at 6:02 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a tutorial showing how to reset the anti-theft system:
https://www.2carpros.com/articles/how-to-reset-a-security-system
When you scroll down the page you will see Honda. Hope this helps and thanks for using 2CarPros.
Danny-
Jan 17, 2019 at 6:03 AM
COBYSHOEMAKER21
  • 28 POSTS
I read the instructions, but my car doesnt have the key fob with it. Just a regular key. I bought it used in this condition.
ACROXFORD
When I use my key to get into my carthe alarm goes off. My keyless entry remote is not working and I tried a new battery and it still doesnt work. When I put the key in the dorr to unlock it, the alarm goes off. It will stop after a few seconds. Then I get in and when I put the key in the ignition, the alarm goes off again. Do I need a new keyless entry? If so where can I get it for cheap? And sdo I have to get it programmed to my car? If not, whats wrong with my car??
Oct 27, 2020 at 4:27 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Hi acroxford,
I would suggest reprogramming the remote to see if it helps.
DISARMING SECURITY SYSTEM
Without Remote Transmitter (EX, HX & LX)
Enter vehicle, turn ignition switch to ON position and press disarm/valet button located on left side of dash. The disarm switch will also disarm the system after alarm has been triggered.
PROGRAMMING
REMOTE TRANSMITTERS
NOTE: Up to 3 transmitter codes can be stored in keyless receiver unit memory. If a fourth code is entered, the first code stored will be erased. It is important to maintain time limits between steps, otherwise process will need to be repeated.
1. Turn ignition switch to ON position. Within 1-4 seconds, aim transmitter at vehicle and push lock or unlock button. Within 1-4 seconds, turn ignition switch off.
2. To program next transmitter, within 4 seconds, repeat step 1 . Confirm that door lock actuators can be heard every time a transmitter code is entered.
3. Within 4 seconds after programming last transmitter, turn ignition switch to ON position. Within 8 seconds, aim transmitters at vehicle and press lock or unlock buttons. Confirm door lock actuator operation after each transmitter entry. Turn ignition switch off. Remove key and confirm proper operation of transmitters.
GORDON GREEN
I put the car in the garage over the winter. Did not run it. Tried to start it. Dead. Used my wife's car to jump me. Did not work. In fact, it set off the alarm that I inactivated several years ago. So, went to Walmart and bought a new battery. The old one had expired. Installed the battery, went I put the positive and negative connections the alarm went off again. I can now shift the gears, use the wipers, windows, etc. Before I could not even shift gears. Every time I touch the car or bump it the alarm is set off. If I open the door it sets it off. I can insert the key and shift gears, but, it will not turn over. Could there be another problem that I am not
seeing? Alternator or what? I appreciate any direction on this. Thank you.
GORDON GREEN
Also, when I look inside the car I can see that the light which is connected to the alarm system is blinking rapidly and has been since I installed the new battery.
  • 55,721 POSTS
Hi GORDON,
Is the alarm an aftermarket unit? If so it is in full swing and you need to remove it. If it is a factory alarm the module has shorted out and needs to be replaced.
Let me know what you find
Best, Ken
JIMISH81
Hi i have honda civic 1998 lx car, from last couple of days i am having problem with my security system while i drive my car and stops at the signals after several seconds it security system locks my car and i have to unlock it everytime, i dont know what to do? on my car key remote the number shown me is APS99BT3 how could i solve this problem? please advice
KHLOW2008
  • 41,812 POSTS
Hi Jimish81,
When engine is running, the security system cannot be activatd unless the power from the ignition is interupted.
Are you sure it is the security system that is locking or the engine stalled ?
If it is locking, I would suggest checking the ignition switch.
JIMISH81
[quote:981cedab99="KHLow2008"]Hi Jimish81,
If it is locking, I would suggest checking the ignition switch.[/quote:981cedab99]
Hi, thank you for your response,
well i am not sure either its a security system or my ignition problem but wherever i stops my car after 4-5 seconds car lock sound comes and also if i break the car after that alarm starts so compulsory i had to unlock my car by remote and then continue... can you tell me whats the solution some days ago it stops working and mechanic shown one wire was outside from the horn system of alarm so he fixed that by rejoining that... now he said i don't know much more about this so i asked one of the security alarm mechanic too he suggested to fit new alarm system with 200 dollars i don't want to do like this please tell me what shall i do?
KHLOW2008
  • 41,812 POSTS
Is the alarm factory or after market?
When engine is started (or ignition is turned ON), the alarm system would be notified via power supply from the ignition switch and be disarmed. Your problem should be this voltage signal is not received by the alarm control unit and after 4-5 seconds the alarm self-arms.
While braking, one of the doors switch is activated, possibly due to door out of adjustment and the door switch is barely pushed. Door movement during braking would cause the switch to activate thus triggering the alarm.
Does the door ajar/dome light flickers during braking or uneven road driving conditions?
PJINGV
The keyless entry gizmo has started to work intermittantly. There is no pattern to the problem. It sometimes works and sometimes does not. It doesn't matter where I stand; in front, in back, either side, or close or farther away. I have replaced the battery twice just in case I may have gotten a bad one...no change. Any thoughts?
Oct 27, 2020 at 4:28 AM (Merged)
TOPGUN1226
  • 29 POSTS
I had an issue like this with my original keyless fobs that came with the car when I bought it in 00. I recently (about a year ago) replaced my fobs with one from an eBay store - used, but had a new battery included - and that seems to work a lot better - and I get better range too.
It seems like it's a different "model" of keyless fob, perhaps for the 01 model or they just updated the original 00 model, but it works pretty well, very pleased with the 30 bucks I spent on the new fob.
JAYBEPR
Hi, i have a litle question, is the 1999 Civic Keyless remote FCC ID#A269ZUA106 compatible with my 1998 LX that from factory use a FCC ID#A269ZUA101
I have no remotes at this time but i have the OEM Radio, i think that all LX models with OEM radio accept Keyless remotes, can some one correct me if i am wrong. Thanks.
THEDARK_MASTER
1998 Honda Civic
alarm from my friend which is called CNSAC. Some of the wires on the alarm diagram i have no idea where to connect them to. Here is a picture of the wiring diagrams, i labeled each wire with numbers on the alarm wiring diagram and letters on the car wiring diagram so it will be easier.
Ok so here is what i know:
1=k
3=l
8=h
9=r
10 = ground
11 = a
12 = j
13 = j
Here is what i dont know:
14,15,16,17,18,19
Here is what i dont think i need:
4,5,6,7 because that is just to shut off the engine in case of theft correct?
2 because i am using 3 since it is a negative door trigger
  • 31,937 POSTS
Hi there,
There are some evidence that claim better mileage, these are a defuser ? swirl plate that is believed to increase combustion efficiency, this i have not sen first hand, but there is plenty on the web. I would like to know what he actually installed and where in the induction he fitted it.
Mark (mhpautos)
ACOSTAAE
  • 14 POSTS
I have a 97 honda civic 5 speed won't crank lights turn on battery and starter is good alarm light on all the time
ACOSTAAE
  • 14 POSTS
O yeah n it starts up good when u push jump Start it
start with a battery test first before going anywhere. it may a simple repair. basics first.
KHLOW2008
  • 41,812 POSTS
If you do not have even a slight click while turning the key, it most probably is not the starter or battery. The immobilizer would be the cause.
Try using a remote wire to jump the starter solenoid with battery voltage to test if it cranks.
ACOSTAAE
  • 14 POSTS
All I get is humming noise under the dash. Could it be the ignition switch
KHLOW2008
  • 41,812 POSTS
Guessing doen not work. You need to perform tests to find out. Get a testlight ready and have you done as advised?
ACOSTAAE
  • 14 POSTS
KBANNICK
the alarm will not let the car start, I have bought a new battery for the keyless entry. every thing turns on but the car will not start. diasabled the siren but alarm stays on. i have tried removing battery, removing fuses to security system. tried key in the door. how do I disable the security system?
DAVE H
  • 13,383 POSTS
TRANSMITTER PROGRAMMING Insert ignition key into ignition switch. Turn ignition switch to ON position. Within 10 seconds, press and hold valet switch for at least 5 seconds. See Fig. 1 . The sound of lock actuators turning to UNLOCK will be audible. NOTE:If radio tuner is ON, it will go off and come on again when programming procedure is completed. Within 10 seconds, press one of the transmitter buttons. The sound of lock actuators turning to UNLOCK will be audible. Turn ignition switch to OFF position. After storing its code, ensure transmitter works properly by repeatedly pressing one of its buttons. System begins working after pressing any transmitter button 6 times. NOTE:If it is desired to program codes of more than one transmitter, repeat step 2) within 10 seconds with next transmitter. Fig. 1: Storing Transmitter Codes Courtesy of AMERICAN HONDA MOTOR CO., INC.
https://images.2carpros.com/forum/automotive_pictures/266999_valet_1.jpg
ACOSTAAE
  • 14 POSTS
K I replaced the starter bypassed it to make sure while key is front and on nuetural n starter just runs by it self. Could it be the flywheel. But it still don't crank. But starts when u push Start it.
ACOSTAAE
  • 14 POSTS
And battery is good.
KHLOW2008
  • 41,812 POSTS
How did you bypass the starter?
ACOSTAAE
  • 14 POSTS
Lol. K im sure a perfessional wouldn't recommend it 0:) but with a screw driver to both bolts. But only did it two times I didn't want to burn it out
KHLOW2008
  • 41,812 POSTS
In one of my previous post I told you to use a remote wire to apply battery voltage to the starter solenoid. That is the proper way. Using a screwdiver and at the wrong terminals, that can mean disaster if anything goes wrong. Under such testing, the starter would run but it is not going to engage as the pinion gear is not being pushed out by the solenoid.
At starter disconnect ONLY the solenoid wire.
Get a piece of wire, add a fuse to it and attach one end to the starter solenoid terminal. Touch the other end to the battery positive terminal and see if it cranks. Remember to have the vehicle in NEUTRAL.
Just for confirmation in case the starter is good. We would be doing other testings from here so I need to be very sure I understand you correctly the present conditions and symptoms.
1. No clicking noise when ignition key is turned to crank engine. True/False.
2. Security light stays on during cranking.
3. Dash indicator lights stays on when turned to On or while cranking.
4. Clicking noise of relay underdash, during ignition on or while cranking?
5. Was anything done prior to this occurring?
We are working on whatever information you have provided and if you do not provide the correct information or do not perform work as we suggested, we would be wasting our time as the desired result is not achieved.
ACOSTAAE
  • 14 POSTS
1. Yes there is no clicking noise.
2. No security light stays on all the time with and without putting the key on.stays completely on even when car is NOT being messed with.
3. Yes
4. Yes
5. No
KHLOW2008
  • 41,812 POSTS
We shall concentrate on the starting circuit for now. The starting system is rather simple and not many items to check. Get a DVOM and test light ready and go through the wiring schematics I have attached to understand the system first.
ACOSTAAE
  • 14 POSTS
The only problem I don't have a test light. Or dvom but I can see if I can buy one in the morning. It's 3 am n Perty tired :) thank u berry much Mr machanic I will let u know manyana thank u again :)
MRDANJK
  • 6 POSTS
My key-less entry does not unlock my doors anymore, yet it does engage the factory alarm. My power locks don't work anymore either, the other day I noticed that they would work if I had my driver door all the way open, so I wiggled the rubber boot/cover that protects the wiring from the door to the engine and now they don't work at all, plus my driver side window won't roll down. Any suggestions? Please? Thanks.
Oct 27, 2020 at 4:29 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Hi MrDanJK,
There is a possibility by wiggling the wire harness, you have cause further damage to a bad wire or you could have dislodged the wire connectors.
I would suggest unpluggint the door wire harness connector to check for contaminations or loose contacts. You would have to crawl under the dash to get at the connectors at the side kick panel.
ZAYMONEY
So I have a very known car that has the potential to get stolen. I have an alarm already but I want back up protection, I’ve seen people installed kill switch wire up from the fuel pump relay, I’m wondering if I can make a kill switch wireless. As in on the internet I’ve seen modulars with remotes is it safe to put a wireless kill switch or any other good protection for that kind of car.
JOETECHPRO
  • 705 POSTS
Hey ZAYMONEY,
If installed correctly you could add a second layer of immobilization of the vehicle.
This would however give you one more thing to potentially fail and cause you a non start condition.
If you are more worried about the car getting stolen than it potentially not starting then going down this route is a workable option.
Which motor do you have in your vehicle, i see the options for a 1.5L either 8V, 16V or 16V with VTEC.
Let us know which motor you have and we can provide you with schematics and suggestions of where is best to install a switch.
Regards, Joe
LATERALUS420
94 honda civic, mileage: 115,000. my aftermarket car alarm system stopped working all of a sudden. the remote will still lock and unlock the doors, but will not set the alarm like it is supposed to. i don't know what to do, please help.
BRUCE HUNT
  • 3,754 POSTS
I think you said the key word "aftermarket". I hate alarm systems, but I know there is often a need or a percieved need. You have three options:
1. Pull the alarm out of the car
2. Contact the manufacturer
3. Provide much more info on the system in the off chance that someone else knows about it and hope they respond.
BRYAN08
  • 12 POSTS
I have the car listed above that I have not used for two days and now i cannot make it to start. i noticed that my green key on the dash is not turning on at all and all four ignition coils do not have a spark at all. I bought new key immobilizer and installed it, now green key in dash are flushing. i do not know what could be the problem. please help me on this.
Jan 4, 2021 at 4:24 AM (Merged)
