Air conditioning blows hot
170,191 MILES
MARKOSGARCIA
Recently, my air conditioning started to blow warm air and would occasionally blow cold again. For the past week it has completely stopped blowing cold. I purchased a can of refrigerant that came with a gauge. When I first put the the gauge on the low side, the pressure was in the red. I proceeded to let out the refrigerant that was in the lines (which only air seemed to come out). Once I got the the gauge to read that the pressure was low, I started to fill the system up with the refrigerant. I’m just a couple minutes the pressure shot up into the red before I barely had a chance to put the refrigerant in. Does this mean there’s a blockage in the line? If so, how do I clear out the lines?
Jun 24, 2019 at 12:42 AM
Good afternoon,
The single cans are not a good way to charge a system. The system has to be filled with exactly the correct amount of Freon to work correctly.
You need a set of gauges to monitor the high and low side. Once I know those readings, I can make an assessment of the pressures and let you know what is going on.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Jun 24, 2019 at 6:09 AM
