2000 Acura TL replacent of catalytic converter
2000 ACURA TL
112,000 MILES • 6 CYL • FWD • AUTOMATIC
BELITA
I have already bought an after market converter which the car doesn't accept. After the replacement the light is still on.I now understand that it needs a 3 stage made for this car part. Would you know what manufacturer does Acura use? or if I put a Benchmark converter will the replacement be successful?
Aug 25, 2010 at 9:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The fault code for the catalytic converter may be caused by a Mass Airflow Sensor that is slightly out of range. Replacing it will probably fix your problem. As for the after-market catalytic converter, it may or may not be functioning properly. Rather than using the temperature test, the true test is the range of emissions is at the tailpipe.
Aug 25, 2010 at 4:26 PM
